Simp5782
SNOW TACKLER!
So I recently bought an M-61A2 tractor 6x6 for $1,500 it runs but runs like crap. Contaminated fuel. worn out LDT-465 multifuel and not a great supply of parts around here. Ive got an extra 7.3 laying around and have an ATS turbo kit for it as well. The LDT-465 is 478ci rated at 170hp @ 2800 and 330ft/lbs @ 1400. So basically its about the same as the IDI just weighs around 700lbs more and not as near as reliable in my opinion. The fuel density compensator on the multi fuel is a pain.
Ok, so my question is does anyone know what transmission bellhousing I will use to mount the spicer 3053B to the IDI?
Or would I be better off dropping in a ZF5 behind the idi and just doing a 1410 you joint yoke on a 2wd zf5 since my transfer case is divorced?
I am thinking the zf5 ratio would help since my Spicer 3053 has a .85 direct drive 5th with 6.44 gears? I am going to be running 16.00x20(52")super singles as well. I don't think a NP205 behind the zf5 will hold nearly as good. I hope the ZF5 can handle it.
Any suggestions?
Any suggestions?
