69oiler
I don't feel tardy
ok first the battery light came on when i turned off the truck. no key in the ignition and the batt light was on. after talking to Nick i checked the ignition switch and the plug on the alternator. ignition switch had no effect but the light went off when i jiggled the plug on the alt. plus, cold engine, warm plug. upon closer inspection the insulation was worn through on both wires going to the plug. i taped the wires up and the light went out until i started the truck. now the batt light stays on with the engine running.
could the alt have fried from having the plug wires shorted for even a short time?
i get 11 volts at the battery terminals with the engine running. i have a battery charger on it for the night because i need the truck tomorrow but i'm guessing i need an alternator. batteries are less than one year old.
is the voltage regulator internal or external on a SD?
