wildman7798
Might as well roll out another one. My 6.9 has a battery isolator but it doesn't appear to be fully hooked up. Did these trucks come from the factory with an isolator? It looks like a typical RV type adder from the PO. It seems like I might have been smelling a little acid when cruising in it the other day and my amp gauge seems to be off center to the charge side all the time, sometimes farther right than others, as you would expect, but seems to always been on the charge side. So my small brain got to thinking without an isolator the full charge always gets sent through the primary PS battery then feeds off to the secondary PS battery. Is this OK like this or does it cause the PS or primary to go to an overcharged scenario and possibly causing the acid smell I think I caught a whiff of. I haven't put the DVM on them or really even checked the temps to see if one is getting hot. Figured I'd throw it out there and see what comes back. Thanks
