Baby Moose has arrived!!!
Mulochico
Modesto, Ca
The Baby Moose pump, 8 BB code injectors, etc. has arrived!!!!;Sweet :D
Thanks go out to Suzi Agne (the person I talked to) and the crew at Conestoga Diesel. Easy ordering process, and prompt shipping.
Plan is to install either This Sunday or next Thur as my work allows. Studied up on Mel's article, very informative.
Will keep you all informed.
gandalf
Senior Member
CA &/or Maine
That's a good thing, both that everything arrived;Sweet and that you're going to get it all in so soon;Sweet.
Read Mel's article several times, the part which applies to what you're doing. Then keep it handy when you're actually doing the job. It's not really a hard job after that. Just take it slow and easy.
Report your progress please.
GOOSE
Happy IDI'er
Galloway Twp, NJ, USA
Very nice.:thumbsup: My daughters will be jealous hearing that you got to talk to Suzi. They are both quite fond of her after attending a couple of rallys and getting to ride in the Lady Moose.:sly I'd pressure wash and blow dry the engine with compressed air before I started the IP and injector swap. Good luck and keep us posted.;Sweet
;Sweet:slyWell good for you.. and be happy. Crack a smile too....:thumbsup::D The post about cleaning off the top of the engine is a great suggestion. What shape and brand are the glow plugs... Good time to replace them too when all the lines are out of the way. Another great thing to do during this is to get a compression test done especially if the glow plugs are out. I know I'm adding on to the work load but some things are easier to do during this work. Remember the three drive bolts torque is 25 lbs. Seems high but those tiny screws are a special hardened material. The also are the same hex and length bolt that holds the rear u joint on the differantial yoke.
GOOSE
Happy IDI'er
Goose, what would you use to block the intake when you washed it?
I'd clean the area directly around the intake first then duct tape over the screen. Do a final wrap around the whole thing and fold it flat. Don't aim for the tape you may slice it.
Mulochico
Modesto, Ca
Thanks guys. I've been planning this for a long time.
Got a new set of zd9's going in when I do it. Probably not going to do the compression test, just can't swing the cash right now for the tester.
I will be taking into account all suggestions, but like I wrote, it has been in the planning stage for over 1-2 years. I have look at all write-ups several times and Mel's article will be there the whole time. I am really looking forward to the project and results.
I keep the engine pretty clean, but the pressure wash is a definite yes!!!
gdhillon
PG...Canada
I have, the same items sitting in my closet waiting for the warm, weather to be installed, take lots of pics please :)
That makes sense, in areas where theres lots of crud do you think I could use a solvent like brake clean?
Brakeclean will do a good job but engine cleaner cuts the baked and caked on crude better. Then cut most of the bristles off a paint brush so the action gets more rubbing done. I use a 1 inch brush. Sometimes I use the metal acid brushes cut down too.
idiabuse
Princeton Fl
Is there a car wash nearby? I use the pressure washer to clean engines before I ****** them. I just leave the engine running and spray away! IDI fairly easy to wash out, all the water flows down the valley and over the transmission on to the ground.
Never been afraid to wash a running engine especially a diesel.
Javier
dizdak
Winter Haven, FL
awesome, i just did the exact same replacements about 4 weeks ago baby moose, BBs, and rtn line kit, even the zd9s... it made a hellava difference on start up, and now with the engine much quieter i have to watch my speed sometimes!! great investment, you will enjoy..
Mulochico
Modesto, Ca
I will try. Just might get to excited and forget. :rotflmao I need to remember to take a slow, methodical approach, but it can be hard sometimes.
Not expecting huge power or anything to outrageous, I know the Baby Moose is just (?) a fantastically done stock rebuild. I am pretty sure current IP/injectors are stock (191,000 miles :eek:) so I am just looking for a great running/starting truck. Thanks for the info, it seems that my expectations just might be exceeded. :D;Sweet:sly
Slade
Roseville CA
I'm running the same set up your installing, you should get a pleasant surprise with the increase of throttle response and power. Make sure to set your timing.
idi_econoline
No Bed For Me!
Northern California
.........I'd pressure wash and blow dry the engine with compressed air before I started the IP and injector swap......
Yeh, shoulda done that myself before opening everything up. Valley pan and intake manifold were BEYOND nasty, as the CDR donut was sitting on the valley pan. ACK! Our cleanup wasn't good enough; one of my new BBs apparently caught something unclean, and has been unhappy for a while. :frustrate
Congrats, Alan, on your wise purchase! If & when I ever get my injector miss fixed, hopefully I can come down and check my timing with you. Looking forward to hear your new injection system run! ;Sweet:D:love:
m2rtin
