Axle seal guestion
2stroke
West Reading Pa.
the dana 80 axle seal that i replaced was a 2 piece and the autozone was a 1 piece and is leaking again only days after replacing it.
I have a 91 f350 dully rear axle
u2slow
bilge rat
Coastal BC
Unless you swapped in a Dana 80, you have a Ford (aka Sterling) 10.25" axle.
Is it the wrong seal? or perhaps got damaged on assembly? Is the spindle surface grooved from wear?
hacked89
Bucks County PA
He said it's an f350 DRW with a D80.. Thats factory not swapped.
Do you have a pic of the two piece? I only thought it was one piece.
I had bought a D80 and D60 SRW(hard to find) for a swap on one of my dodge trucks.
You're talking about this right?
Sent from my SM-G955U using Tapatalk
hacked89
Bucks County PA
Not factory in a '91 F350.
Interesting.
I was curious after your response so I looked at the blue oval guide and I see the following for the D80
1988-2009 Ford F-350 (Rear)
1998-2011 Ford F-350 DRW
I'm guessing it was a SRW option in 91 and DRW starting in 98.
Thanks for that.
Detroit80
Wittmann, AZ
Perhaps he removed a Scotseal and replaced it with a standard seal? I've heard of people referring to Scotseals as a 2 piece, even though they're a unitized construction that goes in as a single assembly. Likewise, I've seen several posts over the years of people replacing a worn Scotseal with a "normal" style seal from the local discount parts store, then having massive leak issues immediately.
Alternatively, and just taking a guess here...I wonder how close the dimensions are between a D60/D70 and a D80 or Sterling and D80. I just looked up a '91 F350 on Autozone's website, and they don't even show a D80 as rear axle options. Only a tranditional style wheel seal for a D60/D70, or one that appears similar to a Scotseal for a Sterling 10.25. Perhaps one of these has a close enough OD to work, but is too large on the ID, thus causing a leak?
u2slow
bilge rat
Coastal BC
Interesting.
Thanks for that.
Listing is wrong. 88 is when the F-Superduty (F450) began, and it has the dana 80.
