Attitude EGT reading high?
ISurvivedNMU
Michigan
I have had my attitude in for about 3 month and I never see 300 degrees before I shut the truck down anymore. It seems to stay around 367 at idle... even this morning at 7 degrees out.. My spa would be around 255 under the same conditions... Lateley I have just chalked it up to the attitude being high. Has anyone else noticed this.
My probe is in the passenger side manafold and it does have a bushing to bring me from 1/4 npt to 1/8npt.:thanks: :thanks: :moon: :thanks: :thanks:
BMDMAX
Atlanta, GA
My Attitude and SPA are always within a few degrees during steady state conditions. The thin probe on the Attitude monitor does vary up to 400 degrees difference during acceleration conditions though.
ISurvivedNMU
Michigan
BMDMAX, are your probes on each side of the motor ( pass and driver side manafold )... And what are you idle temps after normal driving.... Thanks
BMDMAX
Atlanta, GA
Attitude pyro = DS and SPA DG211 = PS manifold. Usually around 300 degrees at idle after driving.
ISurvivedNMU
Michigan
So I am definatly high... Thats what my old SPA guage would be.... it would start down from 340 and be at 300 pretty quick.... Wonder if i should call edge or just live with it knowing its high.... You dont think the bushing would hold heat.... Do ya? :confused:
On edit: BMDMAX, I would like to see more of your avatar... It looks like it would be interesting to see what happens.... That still shot could lead to some good TV!
ISurvivedNMU
Michigan
It has done it from the start... So I know the connections ate clean and dry.... Maybe I WILL HAVE TO CALL EDGE....
The avatar is sweet..... it will not show me the size in the thread... Can you check the properties on your machine to see how large it is.... Give a PM
flhrciblueice
"Git 'R Dun!"
KY
Is the probe possibly out of center in the manifold?
Alleycat
