ATS 093 pedestal o rings
jmuenchow
San Antonio, TX
I just converted my truck to have the ats turbo and it is leaking like a son of a gun from the turbo pedestal. Does anyone know the size of the o rings?
pelky350
Springfield, OR
Russ aka typ4 has them, I think I even have a couple laying around from buying a turbo kit from him recently
jmuenchow
San Antonio, TX
Ok I actually found mine in the garage LOL.... I used the wrong o ring....... yeah I know but how do you recommend that I install the turbo. Last time I did it by putting the pedestal first and then the turbo... should I put the pedestal on the turbo off of the truck and then put the turbo with the pedestal on at the same time and do the two bolts to the back of the intake? Either way it seems like a SOB to do. Just want some tips thanks
pelky350
Springfield, OR
I installed pedistal first then up pipes then turbo last, mine was just rebuild so I had to adjust the housing a little bit to align everything. Some bolts are a pain and i had to use just a small end wrench and sit there 1/4 turn at a time lol eventually is gets done make sure all the threads are nice and clean so you can turn the bolts and instal nuts easier by hand so less tightening with a wrench is needed
m2rtin
