Antarctic IDI Build
They're pretty close to HMMWV tires but I don't think they are.
Probably not HMMWV tires, they're 37x12.50x16.5 and he said 40s
Told yous.
You could say I've been around them quite a bit.
I only drove one for about 9 months straight every day......
Thatoneguy
Boerne, Texas
Told yous.
I said I didn't think they were... Not that they flat out aren't lol. I spent a fair share around them too.
Sent from my VS980 4G using Tapatalk
They actually ran a few different patterns. Could have been after your time though. They may have been "experimental." Lol
Thatoneguy
Boerne, Texas
Haha or before my time. 0311??? I only got out last year.
theSHERPA
Austin, TX
Wes--I remember the previous owner had charging issues and bought a new/rebuilt alternator as a fix right before I picked it up. Not sure I ever ran it long enough to know if it still had the charging issue, and it has sat on a battery tender since it rolled home, due to infrequent use.
P.S. did you see the sweet custom Craftsman alternator spacer?
Sent from my iPad using Tapatalk
theSHERPA
Austin, TX
Future mods:
Level suspension--I think rear is higher than front
Move front axle an inch forward
New shocks all around
Bushwhacker front fender flares
New 4" exhaust after turbo install.
Hack front bumper to fit and add OBS vent as temporary fix. Custom winch front bumper as final fix.
Rear disc brake conversion
Add race radios to cab and box
Outdoor shower (with hot water!) using heat exchanger off coolant lines that used to run to rear AC/heater.
Finish plumbing sink in box
Install conversion couch/bed in box
Build swing away tire carrier for spare
Install modified Class 5 trailer hitch (customized from 91 F350 width to 91 cab and chassis width.
Install rebuilt tilt steering column
Swap manual window/lock doors to auto window/lock doors
Fix A/C
Add extra E4OD trans cooler
Repaint/wrap
theSHERPA
Austin, TX
And with that, I will turn this post back to the OP for updates. Thanks again, Wes!
Thewespaul
Bulverde, Texas
Yep the alt looks brand new, which leads to my suspect that it’s the harness. And yes, looks like the spacer I made for my tensioner! Drilling out sockets ain’t fun though
Thewespaul
Bulverde, Texas
Harness checks out good, and while checking everything with the engine running the alt seems too noisy for my liking, going to pull it and have a look what she’s hiding
Cv axle
