redmondjp
. . . You know, something similar to what guys have used to dump a RDT into the exhaust . . .
On drag race cars, I have typically seen check valves that were used on some AIR systems (the ones with 1/2" NPTF threads and a hex on on end, and a 5/8" hose nipple on the other), tied into the header collector at an angle (which will draw a vacuum on the smaller pipe coming in at an angle) to evacuate the crankcase.
Don't know how well this would work on a low-rpm diesel though. On the VW diesels, modifiers used to call the road draft tube the "elephant trunk", and some would put a soup can underneath to keep the rig from marking its spot. Downside to the elephant trunk is that in freezing weather, it can freeze up solid which leads to crankcase pressure going elsewhere (which is almost never good). My 1997 VW TDI engine actually has a tiny electric heater at the point where the crankcase vapor tube enters the air intake between the airbox and the turbo.
Let us know what you end up doing on this, which I'm sure you will!
