All terrian towing tires
aaronr19
ca
Ive been looking around for some good 10 ply all terrian tires for towing.. Only got 11 thousand out of my other tires I haul a 5th constantly and go offroad a lot any suggestions on tires? Would like somthig I could get close to 30 thousand if not more heard some good and bads about hankook dynapros and some BFG a/t. Would like somone with first hand experience 1993 f250 7.3 non turbo have a set of 16 inch rims and 16.50 beleive my truck will fit up to 33 inch tires or smaller. Any help at all would be amazing
I have a set of Firestone Transforce A/T's on my Excursion. I am not sure the ply rating, but they have never left me stuck, not that I go off-roading but I have been in the mud and the muck and they pulled right through. Currently I have about 60,000 miles on them and will probably need replaced before winter (It is the vehicle that gets driven in the snow). I would say they will have close to 70k on them when they are replaced. They are not cheap, but are well worth it.
oztinker47
Blocksburg, California
I tow heavy equipment into some pretty crazy places, so far the only set of tires that have held up have been wild country XTX, they haven't gotten cut up by the loose rocks and haven't had any excessive wear from highway travel, plus they are legal for winter travel in the mountains! No changing tires when the snow flies.
i run Hercules Terra Trac A/T on the Sulaco. No disappointments. 235/85/16 no sidewall contact with each other on heavy loads in the back.
Ruger_556
Ferndale
If you want long lasting buy a truck tire not a sized up car tire... Toyo M-55, Bridgestone Duravis M700HD, Cooper S/T and now S/T Maxx also.
blue67chero
Aviano, Italy
Try the falken Rocky Mountain ats tires I've had good luck with them
Can30Diesel
Agassiz BC
I ran BFG mud terrains (the classic version) for 4 years on my truck. They were load range D (not 10 ply) but they never gave me any problems, they have been through a brutal life.
Dieselcrawler
Professional wrench holder
Quakertown Pa
I too run wild country xtx on my work truck, they did great in the snow this past winter and great in mud. this is on a 2007 chevy drw utility body van that is 2wd. weighs 11000 lbs....I like them
Alleycat
