.well i got the zf-5 down finally. found why it locked down. bearings on the first and reverse gear welded themselves tohte shaft. in the process it destroyed the gears (1st & rev) and the 1&2 syncro bodys also he 5th and rev synchro body. the other blocker rings were border line and im just dumped $900 into rebuilding it. also re did the tcase too and the solid clutch and fly wheel conversion. all in all $1600. how do yall htink i did? did i get a deal for the tranny rebuild t case rebuild and clutch/fw conversion?
