Advice on replacment parts
FiredudeL4
Southern New Mexico
Hey guys, have some issues with my back doors (C.C.) and need some suggestions, 1st, it seems that Im have issues with the door locks i.e. not wanting to lock or unlock sometimes as if the acuators are bad, the right rear door at times does not want to unlock at times, I have removed the door pannel and cut the little zip-tie which seemed to helped alittle and it also at times does not want to open by pulling the door handle on the inside, the left rear door seems as if the acuator is "locked" up if you try to lock/unlock the door it does not move up/down even if you try to manully push/pull the lock it will not move. Does anyone know of a good source of aftermarked replacement lock acuators also my be needing a window motor for the left rear door -cuss -cuss
stay safe out there
Roy :draw
Vinceslamer
