Advice on fuel tank selector valve
catbird7
PA
I think the obs trucks use the same as my old idi which has small plastic clips?
gnathv
Athens, Al
These are the clips you need to remove
the fitting is similar to this
once the clips are out it slides off. I normally remove the clips, spray the connector with wd40 and push the fitting towards the valve and then pull away from valve to remove.
lewisstevey7
