adding cruise control.
90idi4x4
Ohio
When i got my truck the original column was trashed from the po so i replaced it with a regular column. I now have all the pieces to get cruise working again except the column is a non cruise column. What wires do i need to hook up cruise again?? I have original column for parts as needed.
You will need to pull the harness out of the ORIGINAL column and install it into the column you installed. Then everything should work as normal.
JM2CW
Al
90idi4x4
Ohio
Sounds easy enough just got done with it actually and found a hole in that coffee can lookin deal for my vacuum.
