RyanDamo
1 IDI 2 Strokes
Hey guys, i have a few questions about the for 10.25 axle.
First, on my 1986 f350 dually. i changed the hub seal today and was reading the haynes manual and is said pack the bearing with grease. now i know its a full floating axle and the the gear oil lubes the bearing so is that statement completely wrong or is it just to give it initial lubrication.
Second, on my 94 f250. It is a centurion conversion and was converted to dual rear wheels. It has single rear wheel axles with aluminum spacers. If possible i would like to try to get away from the spacers. If i can find dually hubs at a junk yard, are the spindles the same so i can swap them for a piece of mind seeing as a haul some weight.
Thanks for the help!
