mankypro
Learning Slowly...
I've never worked on an automotive ac before and I'm about to recharge the compressor on my f-250 which only blows warm air at the moment.
With the engine at idle and turning on the ac the clutch plate on the front of the compressor kicks on and off for about 5 second intervals - I assume it's trying to reach operating pressure?
Weird, I tossed the gauge I have on it and with the compressor off it reads 0 then with the a/c on it fluctuates between 25 and 45 psi based on the clutch plate being activated or not.
Which reading do I assume is correct the 45psi or the 25? Don't particularly want to overcharge the system.
It was converted to 134 before I owned it. I assume the clutch kicking on and off is normal?
