Can anyone tell me if the a/c clutch is supposed to be engaged in the heat or defrost position? Ive got a 2001 F-150 with the 5.4, and really don't have any heat. The engine warms up good, 195 degrees. I spent 5 questionable hours tearing the dash apart to check the temp blend door, and all is good there. But no matter what position the heat control is in, the a/c compressor is running.So I'm always getting cold air blowing the heat. Any suggestion on what to do other than unplug the compressor clutch for the winter? thanks in advance, Grog.
