milner351
For the first time ever my 97 has let me down.
Problem:
Thursday morning, plugged in - it starts as normal after not running for a week or so - a very cold week in SE Michigan, I go back inside to finish breakfast, come back out in a few minutes - and the truck is not running... and WILL NOT restart, both the fuel filter and water in fuel lights were on.
Trouble shooting so far:
plugged in block heater, put a 75w trouble light near the fuel filter housing, attached battery charger.
Removed fuel filter lid - filter itself and contents of bowl looked pretty good - not gelled up or frozen as I suspected it would be (current ambient temp 10F)
I drained the contents of the fuel bowl, cleaned the gunk off the bottom (I removed the fuel heater years ago) filled the bowl with diesel 911 about halfway, then filled the rest with fresh diesel. Put the old filter back in.
Symptoms:
Cranks at a good speed - sounds normal.
Tach moves as normal - cps OK.
HPOP is full after many cranking attempts.
Smoke out of tail pipe - white puffs, then some blackish if I floor it while cranking.
Sounds like it's "trying" to start, but just won't light off.
Temperature and fuel filter red lights are on while cranking...
Should I replace the fuel filter even though it's only a couple thousand miles old and appears fine visually?
Please help - this thing has never let me down before - and I'm stumped.
I followed the diesel 911 directions by putting some in the filter housing, and the rest in the tank, then I put a few gallons of fresh diesel in that tank as well - for now I'm just trying to start off the front tank.
Problem:
Symptoms:
