94 idi turbo engine replacement
Dieseltrav
North Carolina
I am approaching replacing my engine due to burn rings and a strange knock. I bought a used engine up to valve covers and i have a solid flywheel and clutch to be installed. All accessories will be swapped, injection system, turbo, pulleys etc. I want to replace oil pan seal rear main seal water pump and freeze plugs but am looking for suggestions on things I may want to consider while it's out. Any help with part numbers on listed items is greatly appreciated. Thanks in advance!
Travis​
There is no oil pan gasket used on these engines. There is one available, but it will leak if you use one. Just a good bead of RTV is all you need to reseal an oil pan. That's what the factory did.
