zmck150
Hello everyone, I am trying to help a friend out and get his truck back on the road. From what he told me one day the truck was fine, the next he's going down the road and it seems to struggle taking off from a light. Then it dumped all the transmission fluid onto the ground out of the inspection shield drainhole. So he flat towed the truck to his house where they refilled the transmission (took 8 qts) and it still drove around in 2nd gear. That's when he called me over there to look at it. I played around for a few mins, put it on my trailer and dragged it to my house now.
So far all I've figured out:
According to the underhood fusebox diagram i attached, fuses "K" and "U" were blown, the overdrive light was illuminated saying "off", reverse is fine and when you put the shifter into 1 it feels as if the truck takes off just slightly easier than if it were placed in 2 or drive. Tachometer doesn't work anymore but the Speedo does.
So I replaced the 2 blown fuses, tach worked, shifted great on a test ride, I thought the problems were solved, I went to move it in my driveway and boom same thing again.
Now (1) what should I be testing in the process of elimination to figure out why those fuses are going bad? And (2)why did the transmission fluid dump out on him but I drove it around and it kept the fluid in?
Any information is appreciated I am curious to learn what's causing all this
Thanks!
Sent from my SM-G930T using Tapatalk
Thanks!
