93 Ford Brakes
thunder
Mechanic thinks he has isolated it to one front caliper, can't remember which one. Does that seem reasonable?
jauguston
Retired
Bellingham, WA
Do your brakes pull to one side when braking? About all that can go wrong with a caliper is the piston sticking and that is not unheard of.
Jim
ramon f350
Ft Worth TX
I had the same problem with my 93 I ended up by passing the RABS and taking it off this might be the best oloution for you if you dont mind not having ati lock brakes
Ramon
thunder
Another piece to the puzzle, the abs light came on today for the first time.
akoldnav
Anchorage, Alaska
Ramon, how did you by pass the RABS. I would like to do this on my 90 F350. Did you cut lines or were you able to unscrew the lines that go into and out of the RABS and make a splice? This might seem like a dumb question, but it would sure help me out on my truck.
thanks
akoldnav
IDIBronco86
