93 factory turbo injectors to replace 91 n/a with banks turbo
staxs5000
Phoenix, AZ - U.S.A.
Will the injectors and glo plugs from I think 93 or maybe 94 7.3 factory turbo be a match for a 90-91 original n/a with banks turbo?
Looking into doing serpentine convo. also .
I remember seeing a fan swap somewhere to I think a plastic 6.0 fan but not sure where ... any info would be great
Injectors and glowplugs will swap from any 6.9/7.3 idi.
Glowplugs, I would just get new. The berus.
If you aren't having cooling problems, don't try to fix it.
If you are, you have something else causing it.
Sent from my SM-G900R4 using Tapatalk
staxs5000
Thanks ... I am having slight cooling issues but it's the fan clutch not locking up anymore, was just looking to maybe "update" a few things not really fix any problems but your also right ... if it ain't broke don't fix it ...
Are the berus only available from Ford anymore or maybe packaged under store brand name from parts house?
Autozone, orielly, etc have them.
They'll be in Motorcraft packaging.
Then you just need a fan clutch. Search around here for info on them. Some new ones suck.
Cv axle
