91 f250 dead battery’s
503sp01
Oregon
I’m thinking I have a draw somewhere can’t find my test light. Both batteries will be dead after a week of sitting ones less than a year one on the other is 3 years old anyplace I should start looking before I go and buy a new test light
If you have a little time, I would suggest this first. Make sure that your batteries are fully charged. Then unhook them both and let them sit to see if one is bad and discharging itself. A bad battery will drain a good one too.
bbjordan
Snow Monkey
Ashern Manitoba
Could be a bad diode in the alternator. With the wires disconnected from the alternator, you can test for continuity between the output stud and the case with a Volt-Ohm Meter. One way you should have continuity, the other way you should not. Or just take the alternator in to get tested.
Runningaford
Id/Az
I could've read your op wrong, but it read to me like your batteries are different ages? If so, that alone I think could be your problem.
jwalterus
Made in America
Garrison, ND
Aftermarket radio? If so, what brand/model?
I got rid of my Alpine, it drew a full 3 amps when the truck was off. (Also required a 10ga wire be run for the unswitched power according to the installation instructions.) But that one was far from a "base model". LOL
I currently have a Pioneer, it draws the batteries down to the point the truck doesn't want to start over the course of 3 weeks, but my batteries are 6 & 7 years old.......
taylerperson
