Actually all of the lines are exactly the same lenth for the set except when a timing transducer is installed then the line for the cyl the transducer is installed on is shortened to make it the same effective length. This is true on all mechanicallly injected diesels that use hard lines. Not all 6.9 and 7.3 lines are the same that is a whole nother post.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
