91 F250 7.3L IDI miss- cannot figure it out
Antigrav1117
Dothan Alabama
Seriously - you'd think a cracked line would be obvious- but it wasn't! Couldn't believe it. Thanks Thewespaul- for keeping me grounded.. :) Cheers mate.
Garbage_Mechan
Garbage Mechanic
Central Cal Foothills
Actually all of the lines are exactly the same lenth for the set except when a timing transducer is installed then the line for the cyl the transducer is installed on is shortened to make it the same effective length. This is true on all mechanicallly injected diesels that use hard lines. Not all 6.9 and 7.3 lines are the same that is a whole nother post.
Thewespaul
Bulverde, Texas
I would get the correct replacement line, you can bend them to work but you run the chance of it cracking again and usually not at a convenient time
720Diesel
