LOGANSTANFORTH
- Joined
- Sep 12, 2007
- Posts
- 99
- Reaction score
- 0
I got 6 19.5 white steel wheels with tires with 10x7.25 F-Superduty bolt pattern, all are holding air fine...Load range F...I would like 600.00 for the wheels and tires...For 50.00 I will bring them to you if you are within a reasonable distance...This is a good deal, the wheels are over 1300 new for the set of 6 from Rickson, 6 new tires are going to run about 850 for the cheapies, these tires have ALOT more miles left in them...Let me know if you want more pics I will gladly take them, I got all the time in the world...E-mail me at [email protected]
The 2 front tires are Bridgestone V-Steels, one of them is absolutely perfect, one has a little wear, I would run them but you may get a new one and use the wore one as a spare...Here are the pictures of the Bridgestones...
The tire that is perfect...
This is the tire with a little wear to it...
The 4 rear tires are all in good shape, probably 1/2-2/3 tread on all of them...3 of the tires are Trailboss Radial Ribs and one is a Powerking Radial Highway...All of the tread matches, just one has a different name on the sidewall...
