Deck height and head thickness are critical dimensions and IIRC Gary aka icanfixall has those available so PM him or wait for his response here.
Hope this helps.
Hope this helps.
Hope this helps.
If valves are correctly set to depth required it won't affect piston to valve clearance what so ever.Resurfacing the head absolutely effects the valve to piston clearance.
^^I could figure out the compression np if I sat down and tried. Just studying a lot for work as it is and so that's not my idea of fun haha.There are online calculators to help you with CR calculations. Google is your friend.
I'll leave you with one more word of caution and then I'll stop being an old woman. If time and money are a factor, think how they are going to be impacted if things go wrong.
