smoky6-9
I have recently purchased and disassembled a 6.9l out of an '84 f250. I discovered water in the cylinders and the rust pitting in the cylinder walls. im doing this engine as a rebuild project for school so I am willing to spend the time and money to do it right.
I plan on boring the cylinders as much as needed but to do so the piston cooling nozzles must be moved or removed. does anybody have information on the early press-in style cooling nozzles? should I try to bend them out of the way or carefully remove? or does anyone have new ones because I cannot find anything and Ford considers them obsolete...
I appreciate any help or advice.
engine serial number: 6.9DU2U030234
