84 300td in a jeep looking for more power
Philip1
Northeastern Nevada
I got what I believe to be the 300td (5 cylinder with turbo) in a jeep yj and I was wondering if there is a fuel adjustment screw similar to the old Ford idiot's to turn up the fuel
Cactus Bob
STRAWBERRY, ARIZONA
remove your "alda" and put a washer under it.
thin washer= a little extra fuel
thick washer = a lot of extra fuel
2 thin washers too much fuel.
be careful a little thickness goes a long way.
DO NOT TRY TO ADJUST THE ALDA these are all old and plastic and old rubber inside you mess with them and it will break every time. put a washer under it and be happy with your fingers crossed of course.
Shadetreemechanic
Monteagle, TN
The Alda matches fuel output with boost on these engines to keep them from overfueling before the turbo spins up. Shimming or adjusting will give it more fuel sooner.
I have never shimmed one, only adjusted and never had one break, but I last adjusted one a decade ago so things in them may be more brittle now.
Philip1
Northeastern Nevada
Thanks for the help guys. I just noticed the typo it was supposed to say the old Ford idi's. My bad.
Philip1
Northeastern Nevada
Looks like the alda was previously removed so it should be full flow all the time. Is there any other adjustment to give a little more power?
Clb
Another old truck
nannyfornia
Fwiw???!
I had a guy in my club go from a 22r to an re to a merc idi INSTANTLY to a 4.3...
He had no more power than the re...
Ymmv
Now about
@IDIoit
Cactus Bob
STRAWBERRY, ARIZONA
Missing the ALDA....now that's telling!
Someone was trying to increase fuel and did the ultimate....removed it.
the OM617's injection pump does reduce fuel delivery as it's wearing out, making the engine feel like a semi clogged fuel filter. you might just be dealing with this problem. other issues are worn rings. do you have blow by?
another might be your expectations for that engine. the 617 was never a very powerful motor for it's size.
Do you have smoke at night, in the headlights of the car behind you when taking off? you should see a little bit, but in daytime if you see ANY you are already running rich. or have ring issues. the om617 is a very clean engine when set up correctly and not worn out.
If you decide to adjust the IP itself and can figure out the MB instructions to do this .....you are a better man than i.
just drop a 7.3 IDI in it!
this little 63 ranchero has all the power I could ever ask for....
and now im going insane with fuel mods ;)
Shadetreemechanic
Monteagle, TN
If you have smoke from the tail pipe, Next thing to do is delete the egr if it has not already been done.
Have you checked your boost levels? This is a wastegated turbo so you want to see that it is functioning correctly.
Also confirm that the alda boost sensor line was plugged when the alda came out. It was a line coming off of the back of the intake manifold.
compressionignitionrules
Bluevale ON
have you checked the timing chain or tensioner yet. cam timing can really mess with your power output. one of the most neglected parts of these motors.
HarleyCummins
