texcl
If I leave the 93 na f-250 sit overnight in the cold, and I go to start it, it has a horrible thumping noise for about a second or two then the truck sounds normal for the rest of the day. It will only do this if it has been sitting over night or longer. It was so loud today I my son jumped away from the truck because he though the engine was going to blow. I can't pin point it since it only lasts a second or two and don't trust my kids to start it while i'm under the hood. have any of yall encountered this? I'm starting to think an engine mount is broken or there is valve to piston contact at start up, but it runs like a champ under all other conditions. Could one cylinder have a bad glow plug and not fire causing a temporary dead cylinder till it gets going fast enough to fire it on compression alone? would it cause a thud like that?
