the Green machine badly need a throttle cable as the sleeved guide tube under the spring is gone . I found one At local NAPA or i can order the NOS OEM part # F1TZ-9A758-E . I am tired of poor aftermarket parts that it either doesn't work for long or doesn't fit and you have to home rig it to do.
Is the Napa cable is the right length , right set up as i did not see it in person or should i order the OEM one and be done
