7.3 IDI power specs
dyoung14
Is getting worn out
spencer,tn
I know for a fact my origanal valve covers off my 83 my 86 my 89 and my 93non turbo engine and my 93 turbo valve cover all staet as follows:
83- 170HP
86- 175hp
89-180hp
93non turbo-185 HP
93 turbo- 190HP
hesutton
The Anti-Anderson
Bowling Green, KY
83- 170HP
86- 175hp
89-180hp
93non turbo-185 HP
93 turbo- 190HP
Like I said before: You aren't arguing with me, Tom Brewer provided that information for the Tech articles.
Heath
hesutton
The Anti-Anderson
Bowling Green, KY
The best resource I could find was this IH literature. Look as the IDI specs for the Ford engines. IH had several different HP versions. This IH info only lists the HP and not torque.
Hope that helps some.
Heath
19jackal90
gardner, ny
83- 170HP
86- 175hp
89-180hp
93non turbo-185 HP
93 turbo- 190HP
my fathers 89 dually says it has 185hp @ 3300rpm
FORDF250HDXLT
Maine & Oklahoma
All numbers are at the crank:
6.9:
Max HP 175 @ 3300 RPM
Max torque 318 ft/lb @ 1800 RPM
7.3:
Max HP 185 @ 3300 RPM
Max torque 338 ft/lb @ 1800 RPM
7.3 IDI Turbo:
Max HP 190
Max torque 360ft
Heath
83- 170HP
86- 175hp
89-180hp
93non turbo-185 HP
93 turbo- 190HP
look closely,and you'll see these say the same thing,only worded different with both comments providing additional,but not contradicting info.:thumbsup:
hmmm.
second/replacement engine.a 1993 n/a idi.
hahaha i dunno.:D ask him if he had to replace the engine.
Clydesdale
Nampa,Id
any one else notice that the 6.9 had the option of being 155 hp? was that a CA emissions thing?
on my valve cover id tag, it had a either 155 or 170 specs, my motor 170 was hole punched
FORDF250HDXLT
Maine & Oklahoma
emissions.
that brings up a good point.
there's different injectors,and likely different ip tunes etc variances.
this could explain a 5hp diff,here and there too.
bird hunter
Maine
Yeah I'm still not sure what the spec is as the info reported here seems to differ. Just checked my valve covers and they state 185 hp @ 3300 rpm and on the front cover the 90 is punched out where it reads 88 89 90 and I know it's original. But from what I read on here a 90 should have 180 hp and either 338 or 345 for torque?? Did Ford publish the specs differently than International did??
Thanks for all the info guys.
19jackal90
gardner, ny
ca emissions probly of that year cluster was 180hp and 338ft/lbs
off topic but they made a 275hp 7.3 psd before and while making a 250hp 7.3 psd.... from what ive heard has a diff cam, hpop, turbo, and injectors
rjjp
Needs to go test
Clare, Mi
On a side note, the literature that Heath provided lists a manual shutoff IP for the 86-87 IDIs, anyone know where they were used?
And a glowplug upgrade kit for the 6.9.
phazertwo
Die Summer DIE!
Crawlorado!
hmmm.
my 93's tag has a 166hp and a 185hp. The 166 has a hole punch in it. Since I live in Denver, I would assume that this truck has been in CO its whole life, and has a high altitude set up.
PZ
Silver Burner
Burnin' Oil&Rubber
Beaverton, OR
Anyone notice that the factory turbo setups have such a low power inrease over NA? Do they only run 3 lbs or something? The truck I'm getting has a Banks sidewinder kit in it and it's like driving a Ferrari compared to my NA 6.9
lewisstevey7
