My new idi has head gasket seeping exhaust into the coolant I'm thinking about doing a rering job in it with head studs then a diy turbo kit from r&d just trying to figure out what turbo to use I want to keep it about 20psi boost
Pm no mufflers. He said hes got a banks sidewinder for saleMy new idi has head gasket seeping exhaust into the coolant I'm thinking about doing a rering job in it with head studs then a diy turbo kit from r&d just trying to figure out what turbo to use I want to keep it about 20psi boost
Ats 088(all sealed up finally) 90cc pump/stage1 injectors can see 18-19 psi wot 3000 rpms lol I think a factory turbo may do better though as they build boost faster but I'm not sure the limit of them as far as boost in the higher rpms wish I had one though the 088 doesn't really boost much till 2000 rpms(not ideal to me) it get the job done though. 0-2psi1000-1500 5psi1500-2000 2000-3500 5-19psi after 2k it takes off though! LolPm no mufflers. He said hes got a banks sidewinder for sale
Are you turboed now?
I believe a factory turbo ats088 can get 18# givin enough fuel and if the up pipes are not leaking
And theres waste gate vs non waste gate also.Ats 088(all sealed up finally) 90cc pump/stage1 injectors can see 18-19 psi wot 3000 rpms lol I think a factory turbo may do better though as they build boost faster but I'm not sure the limit of them as far as boost in the higher rpms wish I had one though the 088 doesn't really boost much till 2000 rpms(not ideal to me) it get the job done though. 0-2psi1000-1500 5psi1500-2000 2000-3500 5-19psi after 2k it takes off though! Lol
What would you think a ats 088 Is good for hp and torque? Same intake wheel as factory system but is non gated and has a larger exhaust wheel("p-trim") if the fuel is there?In my experience, both the factory ATS kit and a Banks Sidewinder, Wastegated are both good for about 250 RWHP with appropriate fuel. Good luck trying to get any more than that out of it. Also, they are both good for about 12-15 PSI efficiently, beyond that, you are just creating a lot of heat and backpressure.
If you want to go for a real performance build, find something like an S360 with a really tight exhaust housing. I have a S360 with .63 housing on a Banks up-pipe, and it hit 30 PSI without even trying. Cleaned up a R&D 110CC pump /easily/, and will probably make 300 at the wheels with that pump. It'll probably make a lot more than that with a 150CC or bigger pump, too.
...Of course, once you start getting up beyond 350, you'd better be thinking about Powerstroke connecting rods...
Oh, 250 at the wheels is /more/ than enough to haul a 6k trailer and not really care.I would love to have a idi with 350 hp but I think since it will be a daily driver and just towing a 6k trailer once a month 250-275 will be good for me as long as I'm not the slowest one on the road I will be happy
