birdsteve
Hey all, I am the proud new owner of a 1986 Ford E350 with a 6.9 N/A and C6 transmission. Someone also put headers to dual 2.5 exhaust. I am new to owning a diesel as well, and could use some help.
The previous owner flew from FL to Colorado to drive this thing back. He said it had no issues other than an occasional issue with the lift pump (but whenever I depress the fuel filter valve while cranking, it spews at a high rate). I drove it 3 hours home to Gainesville and it ran fine, except when I stopped to *** in the national forest, it cut out as I stopped, but started right back up and continued the drive fine.
When driving over 55 it makes a steady popping out of the exhaust, almost as if a bracket is broken and bouncing into itself, but it's definitely the exhaust. It puffs a bit of whitish smoke in time with the exhaust pops, and has a pretty harsh smell. It also has some leakage on the driver side above the headers, and the CDR valve looks wet/dirty on the faceplate. The oil reads about a centimeter within the oil gauge on the low end, even though I added 3 quarts. It has the K&N filter, which I've read is bad and has a bit of oil in the intake along with a bit of oily looking dirt, so the CDR might be funky.
It fires right up and then slightly stumbles, but I just give it a tiny bit of gas and it is good to go and sounds like a happy sewing machine. There is a little white smoke when it starts, but goes away until about 40+. The glow plugs click on and off 2 or 3 times, then stay off.
I drove it for an hour at 55 the other day to take it to a body shop, and it died for about 10 minutes before it started again. Then I drove a little further and it died again, but saved it again. Then, when turning into a gas station, it totally cut out, but luckily a guy helped me push it and gave me a ride to auto zone on his harley so I could get some fuel additive, some oil, and some ether in case I couldn't get it to a diesel shop easily. I got it to the shop, but the guy couldn't help me much and suggested disconnecting the intake tube from the airbox. I disconnected the intake tube to the air box in hopes of getting more airflow in, since the tube that carries it back seems like its opening is really small. I ended up limping it home at 40mph for an hour and it made it.
Whenever I hold it at steady speed without cruise control, it feels like it stumbles briefly when I'm over 40 mph every few minutes, and seems to constantly be puffing a bit of light smoke when I'm over 45mph, just enough to notice in the mirror, but as I speed up, it becomes thicker (and eventually pops and puffs at 55+). I pretty much have to limp it at below 45 to guarantee no issues and avoiding anything too catastrophic.
The only gauges it has are MPH, temp, battery, fuel, and oil (level?).
I think it might be the CDR (burning oil and leaking), as well as maybe needing a new fuel filter (general bogging). It might also be the IP or injectors. I'm comfortable with doing most repairs, but haven't done a head gasket or anything that intensive.
What do ya'll think?
ALSO JUST REALIZED, it is likely the fuel filter clogging because I added a fuel additive and I'm not sure if the kid that had it before me used any, so it might have cleared out some of that gunk, but what about the popping etc.
