Eason
lindstromjd how do you have a 1974 Scout Terra?? They were only made from 1976 to 1980 and are 18 inches longer than a regular scout. Eason
I have a 7.3 /zf5 /np205 married under my 79 F350. (sig) I stuffed the motor as far back and down as i possibly could. I had a 2" body lift on it for the super cab swap and every bit is needed to clear the tranny in the tunnel. Really its pretty striaghtforward. Building motor mount towers is the biggest part making everything fit just right, then moving the tranny xmember back. Mine worked out to offsetting the holes, put the foreward holes of the xmember in the back holes on the frame, roughly 4". Contrary to above, i find i have lots of room between the fan and radiator. Enough to space the radiator back a few inches an stuff a 7.3 psd intercooler in there. I have little to no room between the firewall and the back of the engine, i had to flatten the pinch weld on the firewall. One thing to check on after all said and done is oil filter to front diff. clearance. without a lift, a remote oil filter will be necessary. Starter location can be really fun, but its doable. Wiring really isnt all that bad either. I ran most hots to the un-needed ignition power. But had to run a new hot to the GP controller. With the way the front frame crossmember is in the half tons compared to the 1 tons id say you would have a little more room to move the engine without the oil pan getting in the way of the xmember.
On the other hand, how youre going to make the half ton suspension carry an engine thats twice as heavy... thats all yours. The coils really arent going to like the extra 500+lbs. I dont think the D44 ball joints will enjoy it all that much either. And being a 1/2 tno i can assume you dont have the super cooler, which you may want to upgrade to. I improvised radiator hoses, maybe you can find some that will work without cutting, or use the diesel radiator. I know you have to notch the 150 frame to fit the super cooler.
Ok got some pics taken, once i get em loaded ill look thru and see what they look like and post em up if theyre decent
