I played on the dyno with my old 6.2L GM and found that it gained a little by advancing it a touch from stock but at a certain point, about 5 advanced from the stock non-emisssions setting IIRC, the numbers started to drop (and the engine got VERY noisy). I did that with no other changes and with an NA engine, so I don't know how valid it is to this discussion. I think I left it about 2-3 advanced until I finally turbo'ed it and changed all the calibrations to suit. Interesting discussion here!
Thanks for posting. I've mentioned, either in this thread, or another, that advanced timing has diminished returns after a certain point. It stands true with almost any diesel.
And Jake S got it right also. A pump shop will have to fine tune the pump, play with it quite a bit, to get it to keep up timing wise on the highend.
With a DB4, what's the injection rate compared to a DB2? If it can put the fuel out faster, even if it can be at the same volume, it will help in power production. With a higher injection rate, the timing curve can be slightly relaxed, as it can keep up with the burn rate at higher rpm when moving fuel faster.
