kas83
With a lot of talk and speculation as of late as to how these motor will hold together, which platform do you think would be best to base a high performance motor on? Will worry about fueling later, need to have a sturdy base to build off of.
A 4000 rpm, 350 rwhp, ~20 psi buildup that would be streetable, easy starting, and reliable. Thinking of 20:1 or so on the compression side of things if it would hold together. This compression ratio with the boost figure mentioned would be breaking new ground, but I feel it could be done. I don't wanna hear anyone saying there's no reason for turning them that high, or anything like that. I'm talking a serious build for someone that wants a good daily driver, fun time weekend sled puller, quick street truck, so forth. Cummins swap is out of the question, must stay V8 IDI for posterity.
These motors generate good torque, but I feel the extra RPM will be needed to reach the 350 HP goal.
This is a discussion thread, the motor will not be built for a while, if at all, as I'm out of work, getting married and have a baby on the way. But in the meantime, I'd like to brainstorm what it would take to get one of these motors to make power, hold together, and stay driveable. I've read of an IDI dyno'd at 289 rwhp, which equates to roughly 360 at the flywheel, so I don't feel the 350 rwhp goal is too far off. So let's hear it.
And before anyone asks, this comes from building two CTD's over 400 rwhp, one of which is now a 6k rpm, twin-turbo, 800+ rwhp sled puller, and not being able to leave well enough alone.
