6.0 upgrades
Exekiel69
If there is sediment in your degas bottle or your coolant is brown i would deff do a coolant flush then put on you coolant filter kit. it would suck to put on the kit and in 2 weeks you got to replace the filter because it is clogged. did you decide what you where going to do for your gauges
I got Your PM but Yours are off and You can't receive any.
I like the plug IN edge, I'm just curious how does it get the readings, do I need to get the sensors as well?
If I get one of this I'd like to monitor EGT, trans temp, oil temp and water temp.
Thank You.
polksfinest
lakeland
to do the egt's and trans temp you will have to buy the accessory pack you see the way it works is each sensor has a male and female side so you can just keep adding to it that is why i said it is the Lego of tuners all the other readings come from the ECM you can just about do anything with the display as far what info you want to see if you here is a pic of the plug so you can understand what i am talking about
Respectfully submitted
Josh Ballard
Lakeland Diesel
Lance
