Ah, I see...thanks for clearing that up
The Warden said:Thank you for confirming that But, is there a different insert (for instance, it was mentioned that a Dodge gearshift insert may fit) that'll go into the stock knob?
The disk with the numbers is the insert I was talking about. Sorry for the confusion. It pops out fairly easily, if you don't plan to re-use the knob. The insert has little teeth on the bottom that correspond to teeth on the knob, to keep the insert from spinning around once it's installed.adrianspeeder said:I would think the little disk with the numbers could be popped off. I think I remember someone having it spin around and they had to superglue it on, but they might have ment the whole knob.
adrianspeeder said:Oh ok. All the knobs slip easily on and off of all our trucks, even the 4x4 levers. Sometimes I switch the two on dads 97 to see how long he takes to notice. Usually bout a week for him. hahah
Adrianspeeder
jvencius said:Hmmmm--it sounds like you polish your knob quite often... :Sly
