I too did one that was done on the cheap, but only because I did all the fab work myself rather than paying the big bucks fro motor mounts and all the brackets. That will be the determining factor on pricetag, how much can you do yourself. I swapped out a 460 and put a 92 Cummins in mine, used the Dodge trans and made it all work. If you are doing a 4wd, it can be a bit more of a challenge, 2wd's are much simpler to do, no concerns about t-case, front and rear driveshafts and the like. I got extremely lucky on my swap. The Dodge that I got had a Gear Vendor's overdrive unit, and the front shaft worked out perfectly with the Ford rear shaft to position the GV unit to where I didn't cut a single shaft. Turns out the u-joints were even the same, so swapping the yoke from the GV unit onto the Ford shaft made it even easier, no custom at all.
