4R100 Oil Pan on E4OD?
direwulf23
Botkingburg (NCen), AR
Well, any leads on part number/source for the 4wd filter? I'm not getting a definitive answer on Google
1994 Ford F250, 2wd, 7.3L IDI, NA, E4OD
direwulf23
I realize the cooling doesn't happen. All of the other after market pans I found were at least $50 more. I'm just not a fan of dealing with dealers
gandalf
Senior Member
CA &/or Maine
Same bolts. E4 and 4R are the same.
The bolts screw into the threaded bolt holes in the transmission body, so the same bolts which came out will go back in. If you saved them from the previous pan, and they're not buggered up, then you don't really need the new bolts which come with the kit, although I'd use them just out of principal. If you buy just a pan then reuse the old bolts. Be sure you have a good gasket, and do not overtorque the bolts. I would go with the factory pan.
olsen726
