440 MOPAR
indian347
deerfield bch fl
Any one here good on trouble shooting this monster. My brother rebut it and bored 30 over !Added a high rise and 2-4 barrel Holleys. Added a high pressure oil pump from Summit !Now is been running good. But he developed a slight rear main leak . He has a few miles on it and decided to change oil to syn !!! Now the rear main got worse also his oil pressure doped from 60 when cold to [ 0 ] when hot !!! So he changed the filter & put another gauge on it but it stays at [ 0 ] when hot. Also the lifters du not HAMMER AT ALL. Thats what i can't figure. We sure need some help on this one. Oh by the way its in a 71 Cuda Thanks much Jim
Roland_Jenkins
Señor Member
Nevada
Worn cam bearings can let the oil pressure drop. 440's have poor oiling. At high RPM they can pump the pan dry. Unless the oil drain holes in the heads have been opened up.
If it were me I'd swap back to a stock oil pump or change the spring out of the high pressure one. Not a big deal due to the oil pump being external.
I would also drop the oil pump out to make sure the oil pump drive shaft didn't snap off.
dieselbeef
im guessin if ya didnt braze the pickup tube on that it fell off..common issue
synthetics will always leak more than dino oil
Freight_Train
Traitor to the brotherhood
Gadsden,Al
Might look at the pump.High pressure is not the same as high volumn.Might not have enough volumn to keep up.
Except they thread in to the block on a big block.
lewisstevey7
