400m Tranny Swap.
Dually Lover
Gearhead
Wisconsin
Hello, At the moment I have a 1978 Ford F150 with a 400m and a C6 auto tranny. i want to Swap it to a Borg Warner T-19. The Borg Warner T-19 is off of a 6.9 IDI. I'm wondering if anyone knows weather the Bell housing will match up and if now what bell housing would i need.
I know that the 400M is based of the 351M. i cant find anything online about what bell housing would be needed to swap the T-19 to the 400M
Anyones input would be greatly appreciated.
(By the way Yes i have thought of dropping the 6.9 in to my truck with the T-19. but im saving the 6.9 for a bigger 60's-70's Crew-cab Dually 4x4)
Hardass559
89 7.3 banks turbo
falconer/new york/usa
big block bell houseing diesel is diffrent you may have ishues with clutch kits as well the diesel has a biger input shaft than a gas trans from my experiance
Dually Lover
Gearhead
Wisconsin
From what i know the 400m has the same bell housing bolt pattern as the 460 and the 429, but idk about the 6.9 IDI.
Hardass559
89 7.3 banks turbo
i said diesel is diffrent did i not you may get more outta ppl hear if you tell them you have a diesel 4 speed bell houseing for sail ... maybe you could make a few bucks
opusd2
BFE, WI
Or if you want, I have a tranny and/or bellhousing that you would be able to use. I mean, in exchange for the 6.9s bellhousing and/or tranny of course...
We are both in WI, so this would just mean a little ride to meet depending where you are.
opusd2
BFE, WI
And I do have a C6 for the 6.9 as well as a lot of 70s truck parts. We 'Sconnies need to stick together!
esandifer08
