4 speed troubles
S-west
Ct
Ok so I separated the trans and t-case and when I did the shaft coming out of the back of the transmission slid out about an inch. Now I can't shift it or get it back in all the way. What am I doing wrong
hesutton
The Anti-Anderson
Bowling Green, KY
It's should not have done that. There is some amiss in that T19. Not had one apart, but my fear is a snap ring is broken/missing that holds the shaft in the bearing/trans housing allowing it to move. Now the gears are off their normal location and can't move on the shaft........ can't shift anymore.
Will see if I can find some diagrams or rebuild info on the T19 for ya. Post back when/if I find that stuff.
Heath
S-west
Ct
Ya looking at that there appears to be a snap ring missing. However I don't have the t-19 I'm using a t-18 but it still should be the same I assume. Looks like I'm going to have to pull it apart anyway to get it back in all the way
hesutton
The Anti-Anderson
Bowling Green, KY
The main difference is 1st is not synchronized on the T18. That's about it.
Heath
S-west
Ct
Ok. Well the clip is there. I pulled the top cover and found that 2 gears seperated. aligned them up and slid them together. Works again. I'd post pictures of what came apart but I haven't figured that out yet.
hesutton
The Anti-Anderson
Bowling Green, KY
:D:rotflmao:D
Glad you got it back in the correct spot and shifting again. Once you find the cause, please post back. I'm curious now.LOL
Heath
MadScientist
