4-spd clutch noises
LCAM-01XA
my very own hell
Firing up truck after T19 swap, got greeted by some horrendous noises from inside the bellhousing. Sounds like something is vibrating like a madman. Pushing clutch all the way in makes it stop. With trans in neutral letting off very slowly it doesn't seem to come back. Letting off quick (normal) it's instantly noisy again. Noise is intermittent in gear too, regardless of which gear trans is in. If idling in neutral while it's quiet, messing with the clutch fork (obviously the slave cylinder end of it) can make it get noisy again...
Edit: turned out to be a harmonic vibration with the engine speed, 700 RPMs and below she's loud, 725 and up she's quiet. Idle set at 750 RPMs now, problem considered solved. Leaving this info here in case anyone else runs into this, it's pretty discouraging to do all that work and be rewarded with them self-destruction-like noises so hopefully this can save someone that aggravation LOL
morerunner
