Alright, I'm back. The install went well. Here's how the day progressed.
I put the front of my truck on ramps to make it easier to get under, it's 2WD and kinda low. The valve cover seepage that I can never cure helped keep the manifold bolts lubed up and they came right off with an impact gun. Next I pulled the pins out of the hangers, cut off the muffler hanger at the welds on the muffler, and dropped the whole system. It became clear fast though that I was gonna have to cut off the tailpipe to get it out. So another 60 seconds with the cutoff wheel and the tailpipe was off, and the whole system was on the ground. That was ALOT easier than I thought it was gonna be..
Here's the systems side by side:
The old Y-pipe went under the cross-member, the new one goes over, and doesnt show from the side of the truck. I always hated the old system hanging down below the frame for all the world to see. The new exhaust is up out of sight:
The Dynomax kit doesn't come with a manifold flange for the drivers side, but the new pipe on that side is the same size as OEM. So to save money, I cut a flange off of the old y-pipe and used it:
Installing the new pipe was a bit of a pita, but with some effort it went on. I had to turn it almost 360 degrees at times to get the hanger pin around the tranny, but it went in about two minutes time.
The rest of the install is self explanatory. My welder was not wanting to cooperate today, something is wrong with the motherboard I think, so I just used the clamps that came with the kit. I did have to go buy a 2 1/4" clamp for the Y-pipe joint under the oil pan area. Here's the final product:
The hanger pin that came with the Y-Pipe was in the perfect location. This kit is for a 6.9L truck up to '86, but the hanger location was the same on my '88 7.3L..
I didn't have time to make a video, but I did get to drive it across town for the game, and it was pleasantly mellow for being NA. It wasn't raspy at all, even when I floored it once going up a long hill, it was pleasantly mellow. Its got a deep rumble at idle that you can definitely hear/feel in the cab, but as soon as I start moving, its not much louder than stock. I'm VERY happy about that. I think with the injectors I got coming from Mel, it'll run smoother, and sound sweet. As far as the butt dyno, I did noticed a bit more power, nothing off the line, but everything after. I didn't get a real opportunity to get on it, but its definitely quicker from 1300 rpms and up, no doubt about that.
Brian, how different does it sound from my truck?
It sounds about the same! Thanks for taking the time to make those. If you've got any more, lets see em! Your's/mine don't sound like a 460 with headers, just has a nice mellow rumble when we get on it. My ear drums weren't plugging up from the drone, the muffler did a good job of calming things down. All in all, I think it was a worthy investment. Time will tell, its only been on the truck for one evening, but I like what I'm seeing/feeling/hearing
Thanks for looking fella's
