Here’s the test sheet and model # of the alternator I used. Its for the 95 3.8l in the mustangs.
I did have to clock the alternator one turn so that wires could go into the side rather than the top (personal preference). Also, I had to modify this case slightly. The fitment in the bracket was great, but for some odd reason the alt case bolts on the back are position differently in on this alt in relation to the ears and one of the bolts was coming into contact with the fuel filter column, which restricted the alt from swiveling to tighten the belt.
To resolve this, I just took a 1/2in drill and bored out the case, leaving a step for the bolt to sit in inside the case. This way the bolt head sits flush with the case rather than protrude from the case. I have never heard of this issue so maybe its just this specific alternator or my truck. Shown in the pictures above.
The alt also didn’t have threads in the ear so it needs a nut and bolt to lock down the adjustment, which honestly I prefer. It means you can lock down your adjustment setting from the nut in the back of the ear without having to twist the bolt and have it walk away on you and tear up the track, and you can get it tighter.
So maybe this isn’t the ideal alternator for this swap for some, but besides those 2 things it works/fits like a charm!
