NapaBavarian
Dually driver 6.9
I have an 82 4x4 F250 that hasn't seen an oil change since the PO got it in 98 and I'd like to remove the oil pan to clean out any sludge, I'd prefer to avoid engine removal if possible, how manageable is this?
I took the front spring shackles loose and pulled mine out the front. That is in a 79' with a D60 front to clear. That eliminated the fan, y-pipe, and trans mount steps from what diesel_brad said. Prob 6 of one half a dozen of the other when I comes down to doing it.
But you dont have the HUGE cross member under the pan like the 80-97 does
