351/400M compression?
MMeier
Las Vegas
Buddy has a 79 Bronco with the 351/400 in it, has a solid miss all through out the RPM range, changed wires and plugs, no change. What should a compression test show on this pig? :dunno Has a small RV cam, and headers, otherwise stock. TIA!
aaklingler
Winfield, PA
not much probably around 135, don't know for sure. Look for one in the 60 range to give you a miss. I had picked one up with a burnt valve and have another with a blown head gasket.
ntjapkes
