FordGuy100
could this be used on the old chevy pumps?
I dont see why not, its the same basic DB2 setup
![dunno :dunno :dunno](/styles/default/xenforo/smilies/shrug.gif)
I kinda see what your saying though. If you have maximum power/pressure's higher in the RPM's, the engine would be exposed to them for shorter amounts of time, as the rpm's are higher, and it would be I guess the word I'm thinking is smoother for the engine to do so. Wouldnt have as harsh of power surges as lower rpm's when each piston goes through the power-stroke, higher rpm's would even it out better. Would probably be better for the bottom end.
Also, if you want to turn those rpm's, custom push rods and valve springs should be on your list as well, correct? Dont want push rods bending or the valves floating.
I put the basic setup in an earlier post, but I'll do it again here.
6.9 or 7.3 engine (whichever I get the best deal on first)
Block will get the basic blueprinting, hardblock, and if the bores are good, a torqueplate hone. Of course all the inspections will be done (pressure check, magnaflux)
Stock rods with ARP bolts and better heat treating
Fully prepped stock crank
Everything balanced and blueprinted
Stock pistons, pins
Total Seal rings
Stock heads, unported but perfectly flat decks
ARP studs top to bottom
Custom ground cam with matching springs and stiffer pushrods
Stock rocker arms, deep cryo'd
Columbus Diesel 330cc head unit
200-225cc injectors
Rear mounted compound twin turbos (option 1) or underhood supercharger, 30psi boost
Water to air intercooler
Water/methanol injection
Headers (help reduce the egt's and pumping losses)
Stock intake manifold
Everything gets deep cryotreated and coated
4400-4800 HP peak
2500-3000 Torque peak
5000 RPM redline
You planning on running this thing at the strip only?Hard blocking will cause troubles if you plan on driving on the street!
I would use a 6.9 for this. Have you found a cam yet? Why aren't you going to port the heads?
besides, when a 6.2/6.5 GM can beat you to 400hp or more,
Problem.... The oil cooler draws coolant from the lower end of the drivers side cylinder area of the block. With hard blocking how will you create a coolant channel for that. Maybe lost wax casting???![]()
